I purchased a 7 pin rocker switch but it does not have a wiring diagram.
Anyone have the diagram or can lead me to one?
Seachoice Contura Rocker Switches - On-Off-On, Black, Illuminated Rocker Switch iboats.com Part # 12981
Thanks a lot.
Re: Any one have 7 pin rocker switch wiring diagram?
here is one for the Blue Sea version. It should be similar.
Edit: here is the Seachoice diagram: http://www.seachoice.com/WiringDiagrams/TERMINAL12981.pdf
it is a horrible diagram and is actually very wrong on how you would hook it up. The only pin that gets ground is pin 7. It shows switching both the positive and negative side of a load. You only need to switch the positive.
