Re: Any info on Honda's new 20hp for 03?
Hondon<br />Information I gave is 100 percent true. I am sorry but you are about a 6 hr drive and too far away, if I can not find out the information from a local dealer or Honda then I will buy a Yamaha.<br /><br />Does the 12 amp alternator on the new BF20 motor have a voltage regulator?<br /><br />Can you get the BF20 electric start long shaft without power tilt?<br /><br />Can you get the BF20 electric start long shaft remote without power tilt?<br /><br />Do you have to remove side cover to change oil filter?<br /><br />IS there a way to hook EZ steer up to the BF20?<br /><br />I think this is the best 15 and 20 HP 4 stroke motor out right now. Just need to get a little more info.<br />The things I really like is: 12 amp alternator if has a voltage regualtor / 15" shaft 101 lb, 20" shaft 108 lb, and 25 inch shaft lengths 114 lb / 2 High thrust props / Reverse exhaust bypass for higher reverse thrust but do not see that in manual, but what factory rep said / Flush port / 3 Star CARB rating.
