5150abf
- Aug 12, 2007
- 5,808
I have an '81 Evinrude 50 and am doing a lower unit reseal and water pump, got the top half done fine now I can't get the hub off the prop shaft, this is not the rpop but the carrier just inside the lower that the prop shaft runs through.
The lower is off Ebay and I have run it for 3 years now with no problems but apparently the PO ran it without the front spacer on the prop so the housing is actually machined into the lower case by a big groove and I can't get it to budge.
So far I have tried PB Blaster and heat and I put a pair of vice grips on the hub and another pair against the prop shaft and whacked it but nothing, then I tried a punch and whacking it sideways(this has worked before on a different lower).
I have 2 other hubs so I am not worried about wrecking it I just want it out without destroying the lower casing which I don't have a spare for.
Any ideas boys????
Any ideas boys????
