any help with an alpha one sterndrive?
thesoundwave
I have recently had a impeller problem in which I replaced the impeller and housing and the whole kit. I have had the lower unit off 3 times because I keep getting gear oil leaking out of the small weep hole on the side of L.u. I replace the small o ring on the lower unit where the oil goes up and still have the leak. I can run it, and water comes out great out of that hole, but after I shut it off and the water drains out, here comes the oil again. Not a steady stream but a dip ever 10 sec. or so. Am I missing somthing or is there another seal that needs replacing? Thanks for any help.
xltier
Re: any help with an alpha one sterndrive?
did u replace the lower housing and seal under the impeller plate.could be getting oil up from down below and into the pump area.
Don S
After the repair and when the drive is all back together, you should pressure check the drive to make sure everything is sealed. Without actually doing a pressure check, it's just a bunch of WAGS (Wild azz guesses) what is leaking.
Only you can see it.
dubs283
oh yeah, pressure test, pressure test, pressure test. should hold 15+ psi for 10+ mins while turning driveshaft and shifting fwd, n, rev
the water pump base/seal carrier is sold separatly from the water pump kit, that is assuming this is an alpha one, not a gen II. gen II water pump assembly is completley different from alpha one
