any advise why the stern light won't light.
smallboatlover
Banned
i just bought the attwood pole and base, all round light. i installed it didn't work i took the wires and re did them then even put a new switch in what could be the problem. there's enough power to light the bow light and every thing else to work. i am using 10 gause wire off of it it that to much to use? what can i do to make this work.
produceguy
Re: any advise why the stern light won't light.
A ground wire?
How's that bilge area turning out?????
12vMan
A ground wire?
Like he said ^ ^
If you're sure you have power getting to it, the ground is more times than not your problem. If that's not it, check the bulb. When you check the bulb, be sure to check for power there, too. The wire gauge is fine.
Don S
10 ga is way overkill for a stern light, 16 gauge would work perfectly. If you have power to the light, and a good ground. Check the bulb. I have had brand new lights with bad bulbs right out of the package.
smallboatlover
Banned
well about the bilge it kinda filled with water and froze over the last ice storm so were supose to have a few days of above freezing and i will be getting the water out.
rickryder
Better recheck the weather channel.... forecast snow and freezing rain again Sat Tues and Thurs.
As far as your light.... get a test light, attach it to negative on battery, check for power at the switch, after the switch and at the light.... remove bulb and check where the bulb makes contact in the socket for power....if that's ok check ground with test light....you do that by hooking up the test light to the positive terminal on the battery and when you touch ground it should light up.
smallboatlover
Banned
ok i will try that tommaro and this weekend it suppose to be rain tonight and then 38-40 here so i will get some melting along with the rain and i got the bilge pump out of the ice so i can now get the water out. then i got to make sure the drain plug drains i drilled it in the fall when the boat took on water and i never got to take the foam out of in front of it. theres foam back there that's hard to get to but now i'm going to make a big effort to do this so this won't happen again
smallboatlover
Banned
i found out what i did wrong it was the connection to the switch i didn't crimp it right.
Randy J
good for you if was me be a dead battery lol bad luck better n no luck i guess?
smallboatlover
Banned
ya i rather just a 10 cents fix other than a 30 dollar fix for a new light pole
One thing to do also is to "sand" the contacts of the housing that holds the pole.....if they are carroded it wont work
i have gotten the light to work before by doing that
Stealthbobber06
Five Spice
Should the ground wire light up the test light when the pole is inserted?
Boatist
Five Spice
No the ground side will not have any voltage so it will not light the test light. If the ground side has voltage then you have a bad ground wire to the battery or ground block.
You should put this question in your thread.
