Any advantage to 8mm or larger plug wires
a70eliminator
Gathering up pieces for a complete OMC 5.8 Ford ignition tune-up
Plugs-NGK UR5GP
Sierra- Points&condenser cap&rotor
Wires- still deciding which ones
Ok 8mm wires, advantage other than thicker insulation?
Being I'm still with points ignition and factory coil anything other than the original 7mm plain old black wires would probably be a waste right? Opinions anyone.
Re: Any advantage to 8mm or larger plug wires
Ayuh,...........
Unless you're having radio reception issues,.......
The Stock Wires will do the job at hand Just Fine.............;)
Boomyal
8mm's might be the ticket if you were running an MSD multiple spark ignition system, otherwise as bondo said 7mm will be just fine.
f_inscreenname
But they come in such pretty colors.:D
