I just removed my power head again to replace motor mounts. I was amazed at how well protected the bolts were that I coated with ant-seize. They looked like the day I installed them after 5 years of hard use in the gulf of mexico. The only problem was the heads were rusted to nubs due to the fact that I never painted them after completing my rebuild project.<br /> Now I have to buy new bolts or pute old ones back with vise grips
<br /> Do I buy stainless bolt or just replace with what I had from the factory and coat again with anti-seize but this time remember to paint heads of the bolts.<br /> I heard but am not sure I beleive that if I use stainless bolts that the anti-seize will cause corosion between the aluminum and stainless.<br /> If this is true I might avoid stainless bolts as I hear they are not considered to be very strong maybe being the reason I hear of so many breaking when being removed?<br /> Has anyone else heard of not using antiseize (weather it be nickel or copper based) on stinless bolts used in aluminum?<br /> I know I could use graese, permatex, or pipe dope with teflon on my stainless bolts but I am curiouse as to weather any one has experienced a real problem with anti-seize and stainless bolts?
