workstoomuch
- Oct 25, 2004
- 1
We replaced the impeller on my friends 1987 4hp. Johnson due to no water output out of the exhaust or "tell tale" at low speed (trolling rpm). At any speed above idle, water output is good. Impeller housing looks good. I do not see a thermostat or exhaust plate on this engine to check. The water transfer tube to the powerhead appears to be clear. Any thoughts as to what I might check/troubleshoot? Thank you
