Hello all,
I've read pages of threads about the VRO system, and still quite make a decision.
Last fall, I bought a boat with an 87' 60TLCUC on it, I ran it on muffs before buying it, and it sounded great. It's running about #120 compression on 2 cylinders, and #125 on the third. I checked the plugs after the muff test, and they wern't "overly oily" or "bone dry" so there doesn't seem to be any indications of a malfunctioning VRO (from my very limited experience with it). The PO said it worked fine.
My concerns are that the only thing I know about the system is from what I read on here, some say its great, others say its the devil, I don't know if I should keep using it, or disable the system and run on pre-mix. I've read about marking the tank and running it to watch how fast (if) it drops. I'm not sure they put an alarm on that year(still learning). I'd hate to kill an innocent engine due to my ignorance.
Or should I just take it to the mechanic and have him go over it with a fine toothed comb, and go with his reccomendations?
Thank you for any advice.
