Countrybois
- Jun 26, 2002
- 15
Is there a way to bypass the thunderbolt timing advance module. Here's the scenario. I tried to set the timing with a light and had no success, it seems that the balancer moved. So I ran it up to about 3000 rpm's and set it by ear. Maximum rpm's with no pinging. Now she runs like a kitten, it will restart fine after it's hot if I restart it right away, but if it sit's for any amount of time I have to turn it over for quite a while before it will fire. So I'm thinking it's either vapor lock or timing is advanced a little too far. Is there a way to bypass the electronic advancing module so I can be sure it's not prematurely advancing the timing at idle? Next question, does anyone have a source for timing tape so that I can tell just how far it is advancing? Right now I am guessing, but it doesn't appear that it is truly advancing 22 degrees as it should be. Unit is a 1986 305.
