Augoose
- Mar 21, 2010
- 1,234
I have a '89 Mercruiser 4.3 with Alpha 1 outdrive. After reading the "shift interrupter" sticky as well as several other threads, I'm confident that this is where my problem is. To help me better understand the situation and properly troubleshoot, I have a couple of questions.
According to the sticky...."With an old, corroded lower shift cable, the cable will not allow the Y plate to release and the shift interrupt switch remains engaged. Since the shift interrupt switch remains engaged for a long period of time which keeps the ignition system grounded out, the engine dies completely."
Here are my symptoms:
I occasionally have issues starting the engine. When I gently rock the shifter forward and back without actually putting it into gear, I soon hit the sweet spot for the shift cable, thereby releasing the interrupter switch (I believe) and allowing spark = engine starts.
Quite often the engine will die going from forward to reverse. If I SLOWLY shift, sometimes the engine won't die, however usually it does. I can hear the normal and sudden drop in RPM's where it would normally go into gear, but my engine dies instead of keeps running. Additionally, when I go slowly into gear I can sometimes hear the engine die and then as the pistons are making their final cycles, I occasionally must hit the sweet spot in the shift cable which I assume, releases the interrupter switch, and the engine will sometime just barely jump back to like because the spark has returned at the last minute?
So with those symptoms, I think I'm definitely dealing with a SI issue correct? Moving on.....
I've examined the shift cable and visually it looks to be in great condition. While driving, the throttle handle seemingly moves without any friction or resistance that I can tell, or at least it's certainly comparable to my dad's '01 Stingray with Mercruiser.
Could it be that I'm still dealing with a bad cable that needs to be replaced or is there an adjustment that I can make to the cable itself? If so, what am I looking at as far as adjustment - how can I tell how to adjust it? Or, am I dealing with a failing interrupter switch? Does the switch require adjustment and are they prone to failure?
I've tried to find the answers through searching the threads as opposed to being just another newbie asking questions without research, but I can't seem to find my answer.
Thanks in advance for the help and sorry for being so long-winded!
