BLDFW
- Nov 1, 2008
- 121
I have a '70 Evinrude Explorer with an OMC outdrive. I just installed an SE 300 Hyrdofoil I bought and opened last year. Naturally, having opened it that long ago, I misplaced the instruction sheet however, it's pretty straight forward though I did have one question on the rubber bushings.
There were four, two thinner ones, two thicker ones. With no instructions I made an assumption the busings were to be installed between the foil and the tabs on the outdrive AND, that the thicker bushings were to mount on the forward (to the front) of the foil so that there was a slight downward tilt to the rear of the tab thus giving lift.
Can anyone who installed one verify the placement of these bushings?
Thanks.
Thanks.
