Andrec4016
- Mar 13, 2005
- 57
I have a 83' 140 v4 E140TRLCTE, I've had some history with this one.. but its getting better, when stone cold and sitting in the marina for a week it starts up on the first turn with start idle position once warned up put it in gear and she has no problem getting out of the marina backwards or forwards, then I go out to my fishing spot anchor and stay there for about an hour, then the trouble starts, shes hard to start using the same methods as before stalls when put in gear but once in gear with throttle WOT she runs great, but hard to run in the marina to dock her.. carbs cleaned 2 coils replaced on 1 & 3 no leaks, buld still hard with no change when pumped pump if I give it primer she starts to stabelize and better its almost as she runs out of gas? compression is fine according to the dock master +_ 120 all around any thoughts..
