I looked thru the last 10 pages or so hoping to find the answers but I hadn't yet. My question is; when removing the housing from the lower gear case to replace the prop shaft seal and o-rings, does the housing unscrew? Because I seen on the housing 3 bolt holes leaving me to believe that might be meant for a wheel puller.
My second question; What parts in the drive determines what ratio it is?
The reason I ask is I had purchased a used sterndrive that came off a v8 and I have a 3.0 4 cyl. The lower gear housing was used from the v8 to put on the upper end of the existing drive. When I asked my Volvo mechanic about the ratio he didn't give me any clear answers.
looking forward to hearing from you.
Thanks,
Isleno1
Thanks,
Isleno1
