Another question on me little Evinrude, mixture
tdfayram
I have a used Evinrude 2.5. It has a manual setting fo rthe mixture on the front of the motor.<br /><br />What is the best way to set it?<br /><br />If I recall right, the mixture is set right when the engin reaches the fastest RPM at a given throttle setting.<br /><br />Is that right?
sloopy
Re: Another question on me little Evinrude, mixture
is this the idle mixture?
sloopy
if it is, you set that by getting the engine to run at a nice idle throttle but when you increase throtle it should not bog down.
OBJ
TD...the mixture screw is for low end idle. High end is a fixed jet. To set, run the engine full throttle till warm. Back the throttle down untill throttle plate is closed. Set idle screw for best idle. Then back out about 1/4 turn. This will keep it from running to lean. If unsure of where to start, run screw in until it GENTLY seats. Back out one and a quarter turn or so. Best to do procedure on the water with boat unrestrained.
tdfayram
Very helpfull.<br /><br />outboard Jim, I did get my engine started, seems to run fine.<br /><br />Thanks for all the help, this is great.<br /><br />Tom
