Another question on extending a trailer.
ksubigbuck
Hi guys! I need to lengthen my trailer 2' to accomodate my new (to me) boat, and am planning on just lengthening the tongue. I was planning on sliding a new piece of 3X3 id steel over the existing 3X3 od steel, and I was wondering if the new section has to be welded on, or if I can simply secure it with 1/2" stainless bolts? If I were to bolt it on I would probably go with about a 6" overlap between the existing tongue and new "sleeve".
The boat isn't too heavy, it's a 17ft fiberglass bass boat with a 115 Johnson. I would guess that the boat, motor, and trailer together weigh about 3000 lbs.
Thanks for the help,
Hunter
Re: Another question on extending a trailer.
Ayuh,..... You'll want a Longer Overlap...... A Foot would be minimal,.. A Couple feet would be better,.....
3' or more would be even Better yet.....
And,..... putting a 3x3id over a 3x3od may not work because of the welded seam on the inside will probably interfere....
tashasdaddy
just replace the complete tongue. are your axles movable? may need to to adjust tongue weight, or may need to extend bunks for the same reason.
ksubigbuck
It has negative tongue weight right now, due to the boat hanging a foot and a half off the trailer. After lengthening the tongue and sliding the boat forward the current axle location should be about right. I'm going to try putting in a new tongue if I can.
Thanks again,
Hunter
ksubigbuck
Progress report:
I went to buy the metal for a new tongue...would have cost $175 OUCH! I didn't pay that much for the trailer! Decided to go with the "sleeve" idea. 4 feet of metal tube = $40, much better. Used 1' overlap and welded the snot out of it. The end result is waayyy stronger than the original tongue (but ugly), and I'm happy with it. I was kinda surprised to see that the trailer is only 1/8" steel. I think I'm going to use this trailer until I find a good deal on a heavier one.
Thanks for the help (even though I was stubborn and did it my own way instead),
Hunter
Ayuh,..... Alittle Paint will take care of the Ugly..........
And,......
If you're a Welder,..... Build yourself a Better Trailer........
The Price of Steel comes way Down when you start shopping at Dumpsters.........;)
Alittle over a year ago,....
I built this Trailer in My driveway, in about a month or so,.....
All from Dumpster Diving,+ Returned Favors..........
ksubigbuck
I always wanted to go dumpster diving! Anywhere in particular I should be focusing my efforts? Dumpsters near construction sites or something?
Thanks,
Hunter
Ayuh,......
That's the Big Question in the Art of Dumpster Diving........
Just keep your Eyes Open,+ Never, Never walk by a Dumpster without Looking into it.........
