another question from newbie
dcjcdc
have a 1990 sunbird corsica with 5 lirte omc cobra engine
noticed at the bilge...oil is there..so the water is brownish from the oil
is this normal.....
not sure if a have an engine leak...
my question is i saw a product
engine stop leak by wynn's
mentions on the bottle
helps stop internal and external oil loss
should i use it?
thanks
Rocky_Road
Re: another question from newbie
It is not unusual to lose some oil into the bilge during a normal engine oil change...don't assume that you have an oil leak.
If this were mine, I would monitor the oil level via the dipstick for a while...then decide if I was actually losing any from the engine.
Happy boating!
P.S. Don't start throwing 'snake oil' brews into the engine, until you know for certain that you have an actual leak!
jtmarten
Master Chief Petty Officer
Uhhh, how much water is in your bilge, and how much oil does it take to turn it brown???
You should have no oil in the bilge. Use some bilge cleaner to get rid of all the oil. Check the engine for leaks. Valve covers, timing covers, and oil pans are primary leak sources, as well as sloppy oil changes.
My magic 8-ball says ......... maybe.
Doernuth
Pay real close attention to the oil levels in your engine(s). If an engine is leaking oil it could lead to severe engine damage if your oil level drops too low.
If you locate a leak fix it properly.
Let us know what you find.
Bt Doctur
You sure it`s engine oil and not drive oil????????
