DixieBoatN
- Mar 17, 2009
- 41
I have a 1985 V150 xr2. The Oil injection system is working fine, but I have a short in the wiring or a problem in the warning module causing the alarm to go off intermittently. I know it is not a mechanical failure as I can make the alarm go off by wiggling the wires going to the oil pump rotation sensor.
I have decided to just bypass the oil injection and premix for my peace of mind. Can I not just leave the pump in place and disconnect the wiring and hoses? I know it will likely cause the pump to seize, but who cares? If the pump seizes, the worst that could happen is that the plastic gear inside the motor would get chewed up, but what would it matter? Is it really worth it to buy the block-off kit?
Thoughts?
Thoughts?
