As some of you know, I had the flywheel off on Saturday, 25hp evinrude 1972,to re-align coils. Went hunting this a.m., motor started easy, 3rd pull. Ran fine there and back, about 20min. ride each way. When I went to leave hunting today, I noticed the manual started rope came way out. So when I get home, I pull hood off and it looks like metal shavings inside. O Boy, more fun. The center bolt that holds the spring in place in the very center of started came out. The flywheel was also rubbing on the outer edge of the bottom of the starter. What it looks like to me is the bolt on the starter and the torque nut that holds on the flywheel must have been on each other. So the $64,000 question is, what did I do wrong? Is it possibe to put starter on to tight?
I'm so tired of have problems everytime out. I ready to buy a newer motor, but after being on this forum, there's seems to be no guarantee how new your motor is. I'm just getting frustrated.
