My 1984 Johnson 150hp has been sitting up for a few years. I'd run her with the water hooked up about twice a year. This year, I decided to start getting the boat out to the lake some. I made two very successful trips last month. Then, trouble started up. The week of July 4th, I never left the boat ramp with it....It wouldn't idle. It would only run with throttle at fast idle. This weekend, I ran a pint of Seafoam through it and it idled well at home. After using the Seafoam, I noticed oil or an oily type substance coming from all the water discharge areas of the lower foot (not the tell tail). Is this normal?
After deciding that the Seafoam treatment did help the motor with the idling issue, I decided to head up the lake. At the ramp, I run into another problem. Now, the motor will shut off when I put it in gear. I fooled around with it for at least 30 minutes. The only time that I got it in gear, it felt like it was bogging and the buzzer alarm would go off.
My dad bought this boat new in '84. So it has a lot of sentimental value for me, but I don't to keep throwing money and time into it if its a lost cause.
Any advice on what to check out on a motor that shuts off whenever you try putting it in gear?
