another prob -water temp guage wiring
phillnjack
hello again got water temp guage but cant get it to work right. engine is 60hp merc 1993. put purple wire on the i terminal, tan wire on S term, black wire on G term. the guage went straight to hot when i put the ignition on with very cold engine :confused: . tried the tan/blue wire and that made the horn sound. what is wrong ?. on the engine i can only see a tan/blue wire on cylinder head so where the tan wire is fitted i dont know. do i need a seperate sender and if so where does it go. please help as stupidly ive already cut the hole in the dash for this clock to be fitted. also should the horn sound when i first switch on ignition as mine dont make any noise. it did once when running when the muffs fell off but was switched off straght away. :eek:
Laddies
Banned
Re: another prob -water temp guage wiring
that engine don't come wired for a temp gauge you will have to install a sender--Bob
phillnjack
cheers bob. but where do i fit it to. is it at the top where the brass bolt type plug is.
KCLOST
Sounds like your hooking it up to the overheat switch.... That's probably where the tan blue wire is going...<br /><br />And yes you will have to install the sender where the brass plug is...
Laddies
Banned
Yes you can put a sender in that hole it is tapped to 1/8 pipe
phillnjack
when i fit a sender what do i do with the wire. do i just attach to the s term on guage or what.<br />does it need anything else or is it just sender and enough wire to go to guage
KCLOST
Just the sender and enough wire to go to the guage....
