Re: Another oil question
Woodchopper - just to echo the good advice you've received from these guys. The Merc/Quicksilver oils are excellent, I'm sure, but my opinion is that the guy you talked to gave you self-serving advice. Not BAD advice, just not objective. <br /><br />It's like your car- the most important thing is not the brand, but to use the right type of oil and to use it properly. For your car, this means choosing the weight depending on the weather and other factors and change at proper intervals. For your outboard it means choose a TCW3 certified oil and always mixing it properly. <br /><br />Other than that, the actual brand of oil you use is an extremely minor factor in comparison (imho, of course). You should follow your own inclination as you do with your car. That may be buying whatever is on hand, buying the cheapest, buying a certain name brand, or using synthetic. All are good choices, just as they would be for your car. <br /><br />I've settled into using "not the cheapest" oil - just as I do with my car. Other than that, I buy a decent brand name of TCW3 oil depending on what's convenient when I need it and/or what's on sale. Last couple of years I'd buy either Johhnyrude or Quicksilver oil in bulk (a couple gallons at a time at about $15 per gallon) depending on which boat shop had the best price or which I happened to be near. I tried a gallon of Pennzoil pure synthetic and didn't notice a lot of difference for the $20. Lately, I've bought a couple of cases of Castrol Super Outboard quarts because a very convenient store had it on sale - and to me Castrol has always been a "good" name in oil. Comes out to be about $10 per gallon. Engine's running great on it. My next 'experiment' will be to buy do one of my built in tanks with the cheapest Wallmart TCW3 oil, do the other tank with a "premium" oil and do side by side comparisons. Just for fun. I did that with the synthetic vs. standard grade Quicksliver as well as the Castrol, and couldn't tell any difference in performance or smoke.<br /><br />There ya go.
