Re: Another merc 650 ?.
Artjo, The float bowls are the bottom part of your carbs. If the motor sat for 15 years without being run......I'd say you should take the carbs apart & thoroughly clean them, replace the water pump impeller (maybe the housing too), replace the t-stats, change the gear lube, etc. The original complaint still indicates stuck float valves to me though.
