Oregon Boater
- Mar 28, 2008
- 19
Great forum here
I will jump right in with a question.
I have a 1985 Gamefisher 7.5 and from all the info I have read here already I know that it's made by Eska with a Tecumseh motor.
It will start and die when gas is pumped to it with the pump bulb on the fuel line from the separate tank. I removed the carb and it looks like someone before me did some work on it (or tried to). The float was set so low that the needle was seated all the time. I reset the float and cleared the passages in the float bowl bolt thing. It still will just do the start die routine.
From searching thru all the posts here It was mentioned on several occasions that the fuel pump could be the culprit.
Now here is my problem, I can't seem to find the fuel pump. I can't seem to find any pictures or diagrams of a fuel pump or where it is mounted.
Since my motor does not have a built in tank I figure it should have one. The fuel line goes from the connector and runs directly to the side of the carb.
I am starting to wonder if someone at one time replaced the original carb with the wrong one.
The outboard # is 217-586751
the motor # is 640-23a
on the carb is stamped #1015
I will try and get a picture posted tomarrow.
(I was unable to find a diagram on the Sears site)
Thanks for any info you may have
did I say this was a GREAT forum ?
Jon
Jon
