Another force trim issue
Rsumners
Hey everybody. I'm new to the forum but I have been reading on it for some time now and found it quite useful. However, I'm having an issue that I just can't seem to get my arms around that I would like some guidance with.
I have a 1990 Bayliner cobra with a 1990 Force 120 outboard on it. When I bought it, the trim would only raise up when no load was on it and would slowly bleed down on its own. After reading on this forum for several days, I ordered new seals for the tilt and trim cylinders. I replaced them, but nothing changed. I then changed out the seals on the check valves on either side of the valve body. This corrected the system bleeding down on its own, but the system still wouldn't trim up while under way.
I then ordered a new pump and motor from DB Electrical and got it installed. The motor will now trim up when under way, but will fall under high load when attempting to trailer the boat. I understand the difference between tilt and trim so I'm careful to make sure that I'm still on the trim portion when loading on the trailer. Even when it's on the trim it will still fall just as I'm gettin the boat up to the front roller. Once it falls, it almost gets some sort of hydro-lock and doesn't want to pick up on its own even with the engine off. But if you help it up once, it will begin working fine once again even raising under load, then fall again the next time I go to trailer the boat.
I can get it to repeat in the garage by standing on the foot. It will hold up to a point, then it's like some sort of pressure relief valve lets loose and the motor falls all the way down; its not a slow gradual fall.
Does anyone have any suggestions as to what I should do next. I'm contemplating ordering new tilt and trim cylinders, and maybe another pump as I have read the new pumps aren't nearly as good as the original.
I also was curious if this could be cause by installing the tilt piston in backward? If I remember correctly it will thread on the rod either way and has some sort of pressure relief built into the piston.
Any thoughts would be appreciated.
fisheymikey
Sorry buddy but its not your cylinders thus why you are getting the bleed down.
i had the same problem waisted sooooo many hours but here is your solution.
the good news its gonna cost about 10$ i dont have the pics but do a search with valve body repair ... you are looking for a guy Ritt that responds.
its basically were the 4 npt goes in.. thats called the pump valve body assbly. you have to separate a small piece and install a rubber washer from a briggs and stratton part.
like i said dont have the excact info but im sure you could find it.
and by the way after 3 years and still working great
Frank Acampora
RRitt has passed away and we shall all miss him. He was THE definitive authority on tilt/trim systems. You should be able to look up some of his past posts though.
There is a pressure relief valve within the pump and the tilt cylinder has multiple pressure reliefs so the if you hit something the engine will kick up and slowly return to running position.. You need to check the ball check valves inside the pump and the spring loaded ball relief valve. Also, be certain the shuttle valve is free and not hanging up. I don't know how to check the relief valves in the tilt cylinder piston.
fisheymikey
holly crap.... Rrit was amazing guy help me out soo much now im sad.
god bless
jerryjerry05
In the factory manual there are steps for testing the T/T system.
But it sounds like there is something else going on in there?
