I have a 76 40hp. In my manual it says that the adjustment is 1 5/8 to 1 1/2 from the bowl. But on the diagram the float is all the way dowwn past the high speed nozzle. I am not sure which to go by. I am sure it is the measurement, but I have tried both and the motor will not perform.
Also, do you make adjustments to the hish speed nozzle like the slow speed needle valve, or do you just tighten it all the way? Thank you in advance.
