Boomyal
Thread starter- Joined
- Aug 16, 2003
- 12,072
My son's computer had developed an on/off problem. It is an AMD running XP Pro. The computer began to not respond to turning it back on after a proper 'shut down'. My son removed the switch lead from the board and shorted the two pins. Voila, the computer started and it works every time we try it. <br /><br />I checked the continuity on the normally open on/off switch and it works perfectly and consistantly. We then tried it using the 'reset' switch, plugged in to the on/off pins. It did not work either.<br /><br />Any ideas??
