Another '59 Johnson part question
LukeB777
Thanks for all your help guys. I have another part question. What is the gasket called that sits under the powerhead base. Not the head gasket but what the powerhead itself sits on. And anyone know where I could get one?? Or a solution to work around it if I cant find the part? Any help would be greatly appreciated!! Thanks again!
LukeB777
Re: Another '59 Johnson part question
Are these gaskets even available anymore??
steelespike
Really surprised you didn't identify your motor.
Pretty sure the part you need is available at any well established BRP
dealer.You may need the part number and someone may be along here with that number.
rolmops
That would be #306735.
That is, if you mean the gasket that sits at the base of the block between the engine and the exhaust housing assembly
LukeB777
Boy that was dumb of me. Its a 1959 Johnson seahorse 10 hp. Model QD-20. Thanks for the responses. I will use that part number and check around
rolmops
Don't bother.I gave you the number for a 1959 35 horse
