So I’m continuing my search for the no spark issue on my 1996 40 hp 4 cylinder mariner magnum electric start. I say “continuing” because I did the tests with an unpredictable meter the first time. Anyhow, this is the summary:
No spark on any cylinder
Stator ohm’s tests ok
Trigger ohm’s tests ok
Ignition coil ohm’s tests ok
Ignition key switch tests ok
There is no Mercury tilt stop switch (that I can tell!)
So....I don’t have a DVA to do the voltage tests. But, from the tests above, am I safe to say that it is the switch box? Could it be anything else?
Thanks!
Thanks!
