Re: Anchoring an Inboard Ski Boat
88skiboat, Where do you anchor? Salt or fresh (as in tide swing vs. no tide swing)? You need to be concious of that as well as your draft.
26aftcab454- you have the scope thing partly right. First, 7:1 is not automatic. I use as little as 3:1 or 4:1 in the calm and as much as 7:1 when it isn't. Some of that depends on the suitability of your anchor and whether or not you have chain in your rode, which increases holding power,
Second, when calculating rode length (scope) you want to use the depth of the water PLUS the height of your bow cleat above the surface of the water.
If you're in 5 feet of water, and your bow cleat sits 3 feet above the surface, a scope of 7:1 requires 56' of anchor rode. (5+3) x 7.
