DoctorThunder
- Nov 10, 2004
- 11
I'm trying to install a new achor, bow light switch that has a clear toggle that is illuminated orange...If you can imagine the bottom of the switch, it has three contacts in a row, on one side of the switch and two contacts in a row on the other side of the switch....The middle contact of the three is the hot, the contact before and the contact after the middle contact, switches one light to the other...the two contacts on the other side of the switch light up the toggle itself..one contact takes power, with a jumper from the center contact from the other side of the switch ,with the power, and the other of the two contacts goes to ground...From memory...the center of the toggle should be "off"...one direction with the switch should turn on the anchor light only, and if you move the switch to the opposite side of off you should have both the bow and the anchor light on at the same time...The problem I'm having is,not having the bow light and the anchor light on at the same time..the only thing I can accomplish, is to have the bow light on, or the anchor light on, by themselves..<br /><br />proof reading this really confused me more...sorry guys...<br /><br />help?
