Re: Am I OK - compression reading
You should be good to go given the variations introduced by the gauge itself, your technique, etc. I have a '76 70 HP, and the compression readings were 105-110 on all three cylinders. After a decarb it really didn't go up that much, maybe more evenly 110 across all three cylinders. Decarb definitely blew out a lot of black sludge which I assume was carbon buildup on the cylinders/pistons/etc. The real test is to put it on the water, properly set up for your boat, and see how it performs. If you can get the motor turning at the right RPMs and it puts out adequate power, then you are good.
Rgds
