scottfromoz
- Jan 1, 2006
- 90
Hi all.
I do not use my boat these days like I should/used to. I have a 93 Yammy 115 V4 that I love and it has been a gem. I wonder though how long she will last, particularly doing a lot of sitting around (corrosion on the inside of the galleys). I start her every 4 weeks and run her up to temp on the muffs for about 10 minutes. I use fuel stablizer and a good water seperator fuel filter - fine micron jobby. However sometimes I get caught out either with fuel a bit older than I thought or just fuel evaporation in the bowls causing varnishing/crap in the jets...then its a strip down and clean up and she runs like a dream again.
My worry is I 'upgrade' to a fuel injected motor (I fantasize of an F150 4 stroke) whether it be Yammy or Optimax etc is whether for me that is a bad move. If the fuel evaporates in the rails do you get injector blockages and then if so what is the process and cost of fixiing - assuming ultrasonic baths etc as a minimum and possible new injectors (!!!!)....and of course if I let the fuel go a bit off apart from the problem you can encounter, as with carbs of course, of poor fueling and timing problems from that, am I asking for injector problems etc.
I know that motors of any sort dont like sitting, but I guess I wonder whether I might be better going up to a 150/175 V6 Carbed Yamm new. I know the benefits of injected in terms of fuel efficiency, noise, response, cold start, idle etc and Im not asking about that cause for me and how little Im using the boat all that is not an issue and my 115 runs like a gem hot and starts like a bought one.
Cheers and thanks
PS. Thanks Rodbolt for continuing to be such a great help on this forum, if you read this.
Cheers and thanks
