Am I getting top performance?
jhitt
I was just wondering if I am getting the most out my engine. I have an 87 Century 4000 21' Cuddy with a 260 Mercruiser. I have tuned and tuned and tuned the motor. The only thing I know now is that the secondary on the carb are not opening soon enough.....anyways... I weighed the boat with trailer and it's 5600 lbs,,so guessing roughly 4600-4800 boat and motor. The boat WOT tops out at 33 mph,,rechecked with GPS so speedo is right.
Is that a good speed for the size of the boat.
side note, book says 4400 for WOT, but I only get 4100... also says timing is 8 degrees BTC, but had to advance it by ear in the water to get it to run..
thanks
BAproject
Re: Am I getting top performance?
no..it should be going faster, like 40+
do you have the correct prop?
and you should be up around 4400rpm at WOT
jhitt
thanks
I would guess the lack of RPM could be from the carb secondaries and maybe a tweak with the timing. I have gone through ever thing else.
Motors I know all about,,,anything behind the crankshaft, I'm learning....
The right prop, I don't know. I will have to do some research. We did knick the heck out of the prop on it recently, so a new prop is something I am in search of. But again, I know nothing about props.
I have tuned and tuned and tuned the motor. also says timing is 8 degrees BTC, but had to advance it by ear in the water to get it to run..
Ayuh,... How about a Compression Test during all this Tunin',..??
Like I said in your other thread,... Set the timing back to where it Belongs,... 8?btc...
sethjon
thanks
You're almost topped out. I doubt if your gauges are right on. If you want a little more top end change the prop but realize you will give up a little on the hole shot. 33 is not bad. What are ya gonna do with only about 3-4 more MPH?
sethjon
thanks
Get aprop that is 2 more" for a little top end.
jhitt
with my experience, when you start checking compression you are getting close a overhaul....but I got the guage so why not.
I will got back to square one and try it all again.... thanks for the advice
jtmarten
Master Chief Petty Officer
thanks
I always set timing to have 35-36* at full advance. If the dizzy provides 22*, I set initial at 13-14*. No sense leaving power untapped. If you go beyond 36* you take a chance of creating a nice hole in the top of a piston.
jhitt
so are you saying I may need to keep it advanced for better performance...
thanks
BAproject
8 btdc....
the correct prop and check compressions since you have the gauge
33mph sounds about 10mph off and you said you verified with a GPS
