Fellas, I recently had a 17' aluminum (modified V) flat bottom boat that developed a serious keel leak (no hard pounding either). I was taking on over 500 gph when I arrived at the ramp (my 850 gph pump would just keep up). I won't mention the factory name, but it is a well known manufacturer. They told me that it was very rare for this to happen, and they almost replaced it.<br /><br />However, they had the boat repaired (under factory warrenty, by their local authorized aluminum welder), and I'm not pleased with the job they did. They did not remove the flooring to repair the original centerline crack, but they instead welded each side of the center keel cover by turning the boat upside down. <br /><br />My real problem is, they goofed when welding, up near the front of the boat in two spots, it looked like they apparently burned holes through the aluminum, and filled it in with weld (about 3/4 inches thick and 3 or 4 inches long). I'm afraid that the metal will crack again around these blobs of aluminum, especially since they are near the front of the boat, in a relatively high stress area. I'm trying to convince the factory rep to replace the boat, because I feel additional repairs will only make it worse.<br /><br />What you you guys think? Any aluminum welders care to comment?
