aluminum to stainless steel prop
vettman
have a new 19 ft. glastron with 5.0 220 hp. volvo with 14 1/4 by 21 aluminum prop. wot is 5000 rpm would like to go with stainless steel. would performance increase and should i use the same size thanks for any help
sundancer
Re: aluminum to stainless steel prop
A SS Prop. will only increase your top speed 3 or 4 miles an hour. Your hole shot will be better. But at $300.00 to $ 500.00 for a SS Prop is The ??? You might change the pitch lower for higher top end. higher pitch for better hole shot. Your 21 should be good enough for sking. check out Ace Propellers.com for Props.
Spidybot
oh-oh. There is a lot more to it. Check this link
