Re: Alumi-Weld or Durafix
I used alumaweld to patch a jon boat once. It was not pretty, but it did hold.
I tried propane first but could not get it hot enough. Had to use mapp gas. Hull was at melting point before I could get any flow. Is not as easy to use as in infomercials. Worked decent on bullet holes. When I patched a rip in the bottom, it would crack when it cooled due to thickness of the patch. I would not use it on my Starcraft. It is worth the expense to pay somebody to Tig weld it for you.
