Re: alternators
Assuming you have a Delco style alt-<br />Spark arrestors!!!!<br />DO NOT USE AN AUTOMOTIVE ALT (or starter) ON A BOAT!!!!<br />no spark arresters can (and will) blow up your boat.<br />Not a happy experience.<br />If you need a new alt, you might want to consider pitching that old Mando that you probably have and going to a marine higher output 1 wire. You can order those at NAPA or even from the morons at Autozone, etc.<br />$100 or so.<br />Did that on our old Baja, big improvement in charging and was cheaper than messing with the Mando.
