S/U: 87 GM 4.3 / OMC, 17' Seaswirl<br />Old alternator case broke and I just replaced my alternator and have two questions regarding charging and wiring.<br />The new alternator is a 68 amp 3 wire, the old one was 51 amp 3 wire.<br />Concerned that I don't burn up my battery.<br /><br />The battery was charged and in good condition, we were out for a couple of hours, running off and on and the volt meter is staying at around 14.0 volts. Shouldn't it fluctuate, drop some after being ran for a couple of hours?<br /><br />One reason for my question is as mentioned above the alternator is a 3 wire, one wire (about 12 gauge) is obvious as to where it goes, however the new alternator does not have the other two wires (about 16 ga) "marked" lugs for the sensor / exciter like my old one did. I am 99% sure I got the two wires correct but I thought I would ask the pro's!! <br /><br />What would happen if they were switched, any of you brave hearts tried that yet, any smoke? <br />Is there a way to verify the connections are correct?
