thrashersinc14
Thread starter- Joined
- Aug 26, 2011
- 4
I want to say thanks in advance for any help on my issue. i have a 1987 baja force with a 454 bbc. I have owned this boat for almost a year now and have never seen the voltmeter read over 12. Not surprised because it is 24 yrs old. i always noticed while running wide open it would miss out till you pulled back throttle a little. I also had a weekend where the alternator stop charging i know this because while listening to the radio is started shuting off never having an issue before, so i just put the jump box on it and took off. Well while cruising i could tell it was under power and being a busy weekend i found plenty of wakes and after a big wake jump bam alternator charging again. well i went to searching for that loose wire, on the distributer i found a weak wire on the module repaired it and for the first time i could run full throttle no missing out. well it didnt last long but i havent had an issue with the batterys running dead yet. Just missing at full throttle. i started testing stuff with a voltmeter. battery post 12.79, and at the ignition switch 12.20, when i turn key i power up purple wire with 11.79 while key still on the power side of key switch has 12. then, the coil has 10.78, the output wire on alternator (orange wire) same as battery, purple wire has 10.79, and purple/red wire shows 12.79. i know i shouldnt do this but when i turn the battery switch to off it stays running. so any help for me would be great.
