Re: Alternator output
Howzit,<br />The BF90 has a rectifier/regulator unit. The regulator, when working properly, will monitor and keep constant the output
voltage from the rectifier. The amount of
current (amps) that is driven by the
voltage is dependent on the load which is the charge state of the battery and any other electrical stuff you have on. As long as the load is less than the max rating of your alternator you're OK; if the load is greater, then you'll discharge your battery. So, to answer your original question,
the amps put out at any rpm will vary and is more dependent on the load on the alternator than the rpm, but no big thing 'cause unless you've got too many electrical things running, the amps will always be enough. Leave some fish for me
