Re: Alternative to Water-Glide
Welcome to iboats.
Interesting, you would have to gut it of all the weight you could, I don't think slapping a 400-500 lb weight under the front of your boat would do you much good but if you get the weight down and figured out how to attach it it could work, or not so much.
The problem with doing stuff like that is you never know if it will work until you do it and run it and getting it right the first time is rare.
Also keep in mind what forces this thing is going to be under, figure out what you need to attach it then double that and you might be okay.
I haven't seen your boat or a tigershark jet ski but in theory it would provide additional lift, fi you do go through with this we are mighty fond of pictures here.
