alpha1gen2 5 holed plate and gasket?
Kev.mor
hi all ,
once i got my lower end off this metal 5holed plate with a rubber gasket fell from seamed to be nowhere . not shure if it came from upper or lower ? can someone tell me which part this is and where it would go . i cant seem to find it on any of the how to vids or on a parts blowout . would really appreciate the help !
Rick Stephens
Exhaust shutter. Is at the top of the Y pipe, or single pipe on an inline engine. Keeps water from surging into your motor when you slow down. Need to replace them, yours is burned up.
Kev.mor
thank you very much for the info ! ... on the picture would this be only half of it when i look up the part seems to be a full circle ? i probably have to take the upper unit off also to change this eh :/?
Rick Stephens
Inside near the high point of the exhaust tubes. I don't know what else you might need, or how to get to it since you didn't tell us what motor and drive and model you have.
Ayuh,....... Welcome Aboard,...... That's 1/2 of the shutter, 'n ya gotta pull the exhaust pipe to get to it,.....
It lives at the top of the y-pipe, or down pipe, under the big rubber coupler,.....
Kev.mor
sorry i have a glastron ssv175 mecruiser 3.0l , pulled the exhaust riser and rubber couplers i will try to shop vac the other half out . and thanks alot again for the information i never would of found this out without tearing the whole thing apart !! apreciate to have people with great knowledge and willing to share !
Rick Stephens
Glad you caught it! Parts left in the exhaust can restrict the engine, restrict cooling, and eventually will wear a hole in the exhaust pipe. Spendy little bugger then.
Kev.mor
i tried to shop vac it out , pressure washer , run the engine with the lower end off (had to do impeller) and cant see or feel anything of the second half of the flapper, do i have to pull the upper unit out also?? or could the other half went somewhere else ? any tricks to getting thia bugger out thank you.
Rick Stephens
It could have passed right through the exhaust. Only way I can think of to tell for sure without pulling the motor is get one of those cheap ~$30-$40 mechanics scopes that hook to a phone. Pull the drive and snake it up the exhaust and look.
Rick
