Rpblanchette87
- Jun 29, 2018
- 1
Hi all I recently did a lube job on my lower unit about a month ago. I have it out on a lake trip with family and noticed a whine in only in gear. Most noticeable around 1k rpm. It doesn’t change when I turn the wheel.
https://youtu.be/lb_xhJPESIY
i pulled the boat out and drained the lube and noticed it was pretty burnt for having it in for such a short time and it may have had a slight bit of water in it but not very much. I noticed the upper drain plug oring/gasket came off in bad shape and replaced it. This leads me to believe I had a bit of water intrusion which is never good. I put in new lube and ensured both plugs were pretty damn tight however the noise remains which leads me to believe I may have done some damage. Sound in video starts around 10 seconds in.
my question is twofold:
1: Any idea what could be causing the whine?
2: I am nowhere near a marina that can service this, so what would you think my odds are of making it through a day and a half out on the lake with it the way it is? I’ve already spent enough just getting here and would hate to ruin everybody’s holiday weekend.
