Tominator88
- May 10, 2023
- 31
Hello, new to me boat 87 241 offshore alpha 1 260 hp
My Outdrive goes right up when stopped but wile cruising I can’t get it to trim up at all if I stop raise it then drive it will stay up I replaced pump unit with anouther used one with no difference all my the power wire and jumper to solenoids are new the ground is good I’ve been through it all so many times and gotten nowhere I have no leaks so I didn’t suspect the pistons but they seam like the only thing left I put the drive up it stays up for weeks I jump up and down on it it doesn’t budge any suggestions? Btw I’m pretty good at/experienced backyard mechanic all the soilanoids sesm to be working properly all my wires are correct size anchor tin coated with heat shrink crimps done this year thanks in advance
