Alpha one stalling in reverse
Cody Miller
Dropped my lower unit to replace impeller, now it stall going into reverse. What did i mess up?
thanks
harringtondav
Make sure the bell hsg shift foot and the lower unit shift lever are engaged. If not pull the drive back enough to clear. Put your controller in WOT FWD and the drive lever pointing forward
Hold the prop CCW. Better hold it locked CCW with a bungee Now push it hone. 50 ft lb on the six nuts
thanks
Ayuh,..... Welcome Aboard,...... My guess is, the lower slipped into neutral as you put it together,......
I use a bungee strap 'round the prop shaft to hold tension against the dogs, Lockin' it into gear,.....
