Alpha One shifting problems
PC on the Bayou
For some reason that I can't easily figure out, my outdrive is not shifting properly when the tilt/trim is lowered. With the trim up, it shifts properly into Reverse, Neutral, and Forward; however, when the tilt/trim is down, I will not go into forward. It seems to work if the steering is turned all of the way left, but not when centered.
I was thinking a bind on the shift cable, but am looking for ideas.
