Adjusted my cables. Placed in gear manually, locked prop, 1/8" play in lower cable. Measured 6" b/t barrel center and pin. Placed back on shift plate. Remote cable has 3 and 1/8" distance b/t full forward and full reverse. Spun plastic barrel to exact fit the 4 turns away from cable.
Boat is out of the water.
Gears engage with motor off. When started, no engagement.
Lower unit dog ears?
Thanks guys!
Thanks guys!
