Re: Alpha one. Replaced water pump how clicking noise
I would start by disconnecting the lower shift cable at the engine and see if you can run it thru the gears by hand. By hand i mean hold the cable by the brass barrell and push on the end of the cable. That should put the drive in FWD [prop locks if spun CCW -by hand-and ratchets if spun CCW] Then pull on the cable, a little, it should go into nuetral, prop spins freely both ways. Pull on it a little more and the LU should go into REV. Prop should lock if spun CW and ratchet if spun CCW. If all that works, It is probably just a lower shift cable adjustment.Or the splines are off as others have stated. Search on how to do this or get out your manual and read up. If you cant get FWD-n-REV manually, you may need to replace your lower shift cable.. But start w that maybe and report back .
