I have a 1988 renken 19' runabout with a mercruiser 3.0L and an Alpha one outdrive. When I took it out this past weekend it was very difficult to shift into reverse. The RPM's would increase, but the outdrive wouldn't always shift into reverse. When it did shift into reverse, the RPM's would come up and then "clunk" it would slam into reverse. This went on most of the day. <br /> Back at the boat ramp, the last time I put it into reverse that day, it went into reverse like nothing was wrong.<br />The shift cable was replaced 2 years and adjusted last your by a dealer mechanic. Is it possible the shift cable needs adjusted/replaced, of maybe is sticking?
